Gaspedaal reset
Gaspedaal reset
Berichtdoor Danny » zo 08 mei 2011, 20:25
Quote from: Danny on August 20, 2010, 19:56:03
Was er niet een gaspedaal reset procedure?
even van het UK forum geplukt (met dank aan Nigelo):
With use and due to its design, the "fly-by-wire" throttle system gradually narrows its operating band between idle and full throttle. If left unchecked, this can result in an increasingly sensitive throttle pedal affecting drivability. As it's not exactly insensitive to start with, the result is a PITA with hill starts etc
Whilst you would normally use either an SD2 or SD3 to reset the engine ECU, the factory manuals (Engine volume: page 96 of the Fuel supply section) do contain another approach from the comfort of the drivers seat but do read very carefully.
If you are not sure of what you are doing, leave it to someone who does!
1) Reset the mechanical zero position
Put gear lever in neutral
Switch on ignition (to MAR position) but do NOT start the engine
Do not touch the throttle pedal for 2 minutes
Switch off ignition
2) Reset the mechanical Full Throttle position
Fully depress throttle pedal and hold for 5 seconds
Release throttle pedal completely
Switch off ignition
The full text does not specify waiting until the various warning lights have extinguished themselves after switching on ignition, but I do not depress throttle (item 2) or start timing until they have.
By way of explanation, the no throttle setting (tickover or lower value) is 350/650mv whilst full throttle (upper value) is typically 3,100/3,300mv.
Apparently, the management system strategy gradually reduces the full throttle value by 5mv (for the next switch-on) every time the ignition is turned on (whether engine started or not) UNLESS full throttle is applied for 5 seconds at least once in that cycle (eg climbing a steep hill with full throttle etc). Therefore, under certain circumstances, the full throttle setting will gradually reduce, leading to over sensitivity at the pedal. The manual reset procedure restores the upper and lower values to their default design settings.
Re: Gaspedaal reset
Berichtdoor Emilio » ma 09 mei 2011, 20:37
Klinkt zo hocus-pocus...
iemand dit ooit geprobeerd - en gemerkt dat het werkt??
Re: Gaspedaal reset
Berichtdoor Danny » di 10 mei 2011, 08:57
Emilio schreef:Klinkt zo hocus-pocus...
Jazeker en het maakt een weeeereld van verschil
Re: Gaspedaal reset
Berichtdoor Martino » za 04 jun 2011, 13:06
Hey Danny,
Ik moet toegeven dat ik het ook wat hocus-pocus vond klinken, maar...net bovenstaande uitgevoerd en het resultaat is verbluffend. Ik bedoel, hoe vaak rij je nou volgas? Dat betekent dat de bandbreedte de afgelopen 11 jaar behoorlijk is gekrompen. Super tip! Ik kan de auto voor het eerst als een normale auto rijden! Heerlijk!
Ik ben echt helemaal verbaasd. "(^&$@
Dank je wel!
Martino
Re: Gaspedaal reset
Berichtdoor Danny » za 04 jun 2011, 13:16
Mooi!
Re: Gaspedaal reset
Berichtdoor Yousoef » za 04 jun 2011, 18:06
geldt dat alleen voor de 3200GT of ook QPV?
Yousoef
Geregistreerd: di 17 mei 2011, 11:41
Re: Gaspedaal reset
Berichtdoor Emilio » zo 05 jun 2011, 09:39
Martino schreef:Hey Danny,
Dank je wel!
Helemaal top! %$#@
wel raar dat F. dit blijkbaar geen issue vond, of heb ik je eerdere berciht niet goed begrepen?
Re: Gaspedaal reset
Berichtdoor Danny » zo 05 jun 2011, 09:44
Yousoef schreef:geldt dat alleen voor de 3200GT of ook QPV?
Geen idee, volgens mij alleen de 3200. Maar met jouw gaspedaal is niets mis hoor.
Re: Gaspedaal reset
Berichtdoor Martino » zo 05 jun 2011, 10:00
Ik heb het F nooit expliciet gevraagd en ik dacht dat het zo hoorde. F is een groter autorij-talent dan ondergetekende vermoed ik }{}{| en doet niet gauw moeilijk over een delicate gaspedaal/koppeling combinatie. Ik zie hem met het grootste gemak de meest bijzondere klassieke sportwagens verplaatsen zonder een hik of onnodig lawaai...
Het kan natuurlijk zo zijn dat hij deze reset niet kent, maar dat zou me wel verbazen... 17 juni ben ik er weer en ik zal het eens vragen.
Martino
Re: Gaspedaal reset
Berichtdoor Boomerang » zo 05 jun 2011, 11:10
Achteraf is dat zeer waarschijnlijk ook het geval geweest met de zilverkleurige 3200 in Bergamo waar ik even mee gereden heb.
Wát een hysterisch geval was dat, niet mee te manouvreren gewoon.
De conclusie dat een handbakvariant DUS voor mij niks was, is wat voorbarig geweest.
Bovendien geeft dat aan dat er al lange tijd niet volgas met de auto is gereden.
Had achteraf dus best eens een heel goede auto kunnen zijn..........
