opknappen 222 SR
Re: opknappen 222 SR
Berichtdoor Wietze » di 27 dec 2011, 21:36
The car is almost similar to a 222 4v
instead of a ZF 5 speed as the 222 4v has, i placed a Getrag 5 speed. The engine is out of 430 4v from 1991 as is the 222SR itself. LQPL is right it is a 2.8 24v. 284,7hp and 461nm torq as state the reports of speedcenter Geldermalsen
There were a few changes that had to be made for instance a bigger radiator and heavier fans are placed. A cooler is placed on the differential(came from a chibli first series) further more a cooler was fitted to the power steering
(came from a fiat uno) it is placed between the intercoolers in the front bumper and fits and works greatly. The 15 inch wheels are replaced by 16 inch wheels from a 224 and chibli(7j front and 8j at the rear) the front and rear brakes are slightly modified. This summer the front brakes will be replaced by shamal brakes. The sub frame modification is ordered already and will then be placed asswell.
As for the engine, it has two new heads of the seccond series. The cracked old one s are in my garage. Both turbo's are completely rebuilt.
There are countles minor changes for instance, the gearchange leavers are fitted in nylon instead of rubberbushings as is original. This results in shorter gearchange
later on more?? %$#@
Berichtdoor koen2224v » di 27 dec 2011, 21:42
wietze wat heb jij aan je remmen laten doen?zijn overigens mijn oude velgen achter op jou 222tje
Berichtdoor madmax » di 27 dec 2011, 21:43
You are wrong, 222 4v has Getrag 5, as the Racing
madmax
Geregistreerd: za 13 aug 2011, 21:31
Berichtdoor koen2224v » di 27 dec 2011, 21:49
222 4v always have getrag,222 sr have first years zf and the last year getrag
i have a origenal 222 4v silver!!and a few more maserati's
Berichtdoor Wietze » di 27 dec 2011, 22:32
Koen,
Hardere blokken en de slangen aangepast. Buitenmantel van gevlochten metaal waardoor het pedaal harder wordt, helpt een beetje maar niet genoeg daarom moeten de voorremmen worden vervangen...
Berichtdoor Vince » di 27 dec 2011, 22:36
Wietze schreef:Koen,
Koen,
Harder blocks and the snakes onfit. Outsidecoat of flighted metal wherethrough the pedal harder got, helps a bit but not enough because must the frontbrakings becoming replaced.
(ik vertaal het effe voor die Engelse meneer he?)
Berichtdoor PeterM » di 27 dec 2011, 22:44
Daar zal die blij mee zijn "(^&$@ [Biertjuh] @#$%
Berichtdoor Boomerang » di 27 dec 2011, 22:56
Koen,
Ik vind dat zooo knap he, zo even uit de losse pols. respect06
Berichtdoor madmax » wo 28 dec 2011, 09:31
thanks for the translation "(^&$@
madmax
Berichtdoor Vince » wo 28 dec 2011, 09:48
You know me toch. Always helping the peoples.
